Injectors / fuelrails
Old Sep 8, 2015 | 03:04 PM
Knighthawk1320's Avatar
Default Injectors / fuelrails
Ok so I added some 42lb green injectors and a set of performance products fuelrails deleted the EGR even though it wasn't plugged it had a pp TB but I added a 85mm TB but now it won't stay on and runs a bit ruff so my question is what's giving me problems is it the upgraded rails and injectors plz let me know thanks
Old Sep 8, 2015 | 03:48 PM
Ollie8974's Avatar
Look for a vacuum leak.
Old Sep 8, 2015 | 04:01 PM
themealonwheels's Avatar
Did you get a tune? If not, you're adding too much fuel.
Old Sep 8, 2015 | 04:41 PM
The drivers side valve cover has the brake booster plugged in and the other valve cover has the intake manifold and tb 5hat should be it or am I missing any?
Old Sep 8, 2015 | 04:44 PM
Yeah I thought of that also I figured that could be the problem but wasn't 100% sure but that to is another problem I started another thread explaining that in the Gen III internal engine
