Ls6 Flooded Bad - Scared to start
Old Oct 31, 2015 | 03:24 PM
Tylerweber's Avatar
Default Ls6 Flooded Bad - Scared to start
Hello, I'm new the forum, I've been researching all day on my problem only to find one post similar to mine but didn't really help me out so I decided to make an account and post this...
I've been in the process of doing an ls swap in a 70 chevelle and finally today I finished everything and was ready to start it up. I turn the key to prime the fuel and turn it over and it sounds like it is turning over very rough. No start. Tried multiple times and nothing.
So I pushed the car back in the shop only to find a very large puddle in my drive way and a trail of drips as I pushed it in. It was all gas and it was leaking out of the header's collector on the drivers side!
Now I am afraid of trying to start it anymore because if there is that much gas in there, it doesn't sound like a good idea to add combustion to it.
I've read about the process of holding the gas pedal down while cranking to unflood it but I'm still uneasy about doing that in case it starts.
Any suggestions on how to clear out all that gas and how did this happen?
I have had it running once before for only a second with just open manifold on it, so I have spark with the key...
Any help would be appreciated thanks
Old Oct 31, 2015 | 04:26 PM
Tylerweber's Avatar
Okay so I called a friend who is very knowledgable about ls engines and he said he has never herd of gas running out of the collectors but he told me to remove the spark plugs, unplug the fuel pump, and unplug all injectors and turn the car over a little at a time and watch for gas coming out of the spark plug holes. I did so. And I couldn't believe how much gas came flying out of the #1 cyclinder. I kept cycling the engine until no more gas left. Now I'm gonna leave the plugs out overnight in hopes for any gas left to evaporate.
Then tomorrow I'm changing the oil because I pulled the dipstick and it smelt like gas as well...
So I may have cleaned up the problem now but does anyone know what could be causing this? The injectors are brand new but it seems like that #1 injector is stuck open. I haven't pulled it yet to check tho
Old Oct 31, 2015 | 04:32 PM
HioSSilver's Avatar
Your friend gave you good advice.
Old Nov 1, 2015 | 06:51 PM
LilJayV10's Avatar
more than likely that injector is stuck open internally.
The easiest way to tell that is unhook suspect injector or all of them and cycle the key a few times. if fuel still sprays out the injector needs to be replaced.
If it only shoots fuel out with the injector plugged in it's a wiring/electrical/PCM issue that is keeping the injector open constantly.
Old Nov 1, 2015 | 06:55 PM
Mappinsj's Avatar
Swap injectors see if problem moves
Old Nov 2, 2015 | 06:58 AM
Old Geezer's Avatar
How about, having the injs cleaned and flow tested, before you knock a hole in the block??
Old Nov 2, 2015 | 11:42 AM
LilJayV10's Avatar
Like button.
LMAO
Old Nov 8, 2015 | 08:40 AM
kingtal0n's Avatar
leaking injector, or the injector is getting a constant signal to be open. Check the wiring for each injector; the 12V is constant for example, that is normal. The ECU flips the ground on and off, the FSM will probably explain how to some extent. Sometimes you can run the fuel system with the injectors outside of the engine (take the rail out, leave the injectors inside it, and turn on the fuel pressure. Some rails will allow this) This is my favorite way to test the fuel system because it allowed you to use your eyes AND nose to check for leaks.
Do a compression test and leak down test on the engine also; cranking it over with so much fuel may have bent a valve or bent a rod. I have done this in past with a similar problem, stuck open injector lead to set of bent valves.
