Fuel Pressure Drop with inline regulator...
Old Nov 14, 2015 | 03:13 PM
Tiger2o69's Avatar
Default Fuel Pressure Drop with inline regulator...
At idle I'm holding 60lbs of pressure... driving at a constant speed its fine.. if I give it a little gas it drops off to 40-50 depending how much I give..
I'm running walbro pump, braided line to front, fast fuel rails, magnafuel pressure regulator with boost ref that I am not using..
So far I have
1. replaced pump.. then swapped entire bucked with a friends.. nothing
2. cleaned filter..
3. checked for leaks..
Regulator -
I doubt the diaphragm has a leak but I could buy a new one to check..
Is there a way to just open it up fully to test it?
any opinions appreciated at this point..
OH... Voltage and ground to pump... That's my next thing but I do have the aftermarket racetronix wiring kit.
Old Nov 14, 2015 | 11:14 PM
Jc803's Avatar
I see in your sig it says turbo. If you do have a turbo, and boost ref'd regulator, why not hook it up?
Need more info on fuel line size, how its routed, and is there a return. Sounds like the only variable you havent checked.
Old Nov 15, 2015 | 12:18 PM
Tiger2o69's Avatar
Hey, thanks for the reply...
It us currently not turbo anymore.. Wish it was..
I have 8AN braided to the front with stock return lines.. Its routed in the same place the old line was.. Ill try to post pics of everything today..
Old Nov 17, 2015 | 08:13 PM
Old Geezer's Avatar
W/o the boost ref line on there, the port has to be open to atmospheric pressure.
If it's referenced N/A, then the inj flow data has to reflect that.
