help me with my fueling setup!
i am planning to use the russell push on efi fitting part number 644123 which is a3/8 to -6an for the return and russell 644133 which is 3/8 -8an for the feed.
i have been reading some people do -8an for return as well. should i do this?
as for the boost referenced regulator i have no idea which i should get. im not going to mount it on the rail. im going to mount it on the wheel well. ive been reading good things about aermotive and fuel lab so im leaning to one of those. can anyone recommend me one with part number for my setup and line size.
for the filter im going to be going with what ever brand i decide with the regulator. 10 microns or 25 microns? if someone can recommend me a part number also that would be helpful.
lastly if someone has a diagram on how to route the lines from the rails, regulator, where to put filter etc that would be great.
also do i just disconnect the factory regulator in tank? ive also heard keep the factory evap stock.
thanks for all the advice.. first time im going big lines and running regulator etc so im a noob coming to this.
Put the filter before the regulator. Make sure you have a prefilter before your pumps.
Yes you'll disconnect the in tank regulator.
It feeds to a Fuelab's filter at the stock filter spot, Y's off to each rail from the back. The front, -6AN lines to the FPR. -6AN to 3/8s EFI fitting to the stock feed line from FPR.
I removed stock filter from the loop and added fuel line (-8AN with clamps) in to bridge the original feed line together. Have not ran into issues with this set up yet.
Hope the illustration helps.
