98 Fuel Pump Swap....PROBLEMS!!!!
I do not see how the pump will even go into this assembly the way it is right now. Dont know what to do to make this happen. Any info would be helpful at this point!!
Thanks
Do i use the yellow brackets from the stock pump at all then? TO me it sounds like they are discarded?
Also, with clamping the pump to the bracket.......do i need to keep the pump perpendicular to the bottom?
matt
Only thing i was curious about that is left is the return line like you said. Would i be okay to use some plastic zip-ties to hold the hose to the assembly? Are they gas tolerant?
Thanks for helping me out on this......i thought i was going to have to go the expensive route there for a while and buy a racetronics setup!!
matt
