Difference in injector pricing?
Old Jan 30, 2016 | 12:14 PM
Whisper's Avatar
Default Difference in injector pricing?
So I've been browsing the Parts Classifieds and I see some pretty big variations in fuel injectors. Sometimes you see some that are the same lb/hr but one set will be 100$ while the others are hundreds more. I've been looking to get some more understanding on if the lb/hr is the same, what makes one set of injectors better than another? What is the benefit of flow matching? Siemens Deka seem especially expensive compared to some of the others I see on there.
Old Jan 30, 2016 | 03:29 PM
redtan's Avatar
I wouldn't get $100 injectors at that rate unless they are OEM.
A good set runs in the $300+ range with the better ones being upwards of $800. Yes flow rate is flow rate, but some are better than others in terms of longevity. Flow matching is key as you don't want different injectors flowing different amount of fuel as you can only control the injectors together not individually.
Old Jan 31, 2016 | 06:55 PM
RideRed0331's Avatar
The injectors being flow matched is key, and your tuner will likely need that information (I just went through this personally)
Also it seems the prices vary for LS1 style, LS2 style, and LS3 style. Each are different heights and my require spacers depending on the application.
Old Feb 14, 2016 | 01:25 PM
Whisper's Avatar
One more question. Is there a such thing as too much injector? For example, my car currently has 36# injectors. Would moving up to 55# or more be detrimental to things such as fuel economy? Basically I'm wondering if you lose fuel efficiency simply by going to larger injectors.
Old Feb 15, 2016 | 07:19 AM
redtan's Avatar
Yes there is such a thing as too much injector, but not in your case.
Regardless if you have 36# or 55# injectors, the amount of fuel you command at each point in time will be the same. It's just that the first set will stay open a bit longer than the second set because they deliver less fuel per any given amount of time so they need to shoot for longer.
Now if you get say 300# injectors on a stockish engine, that will be too much because such large injectors cannot spray a small enough shot that your mild engine needs. So at that point you will have too much injector and your fuel mileage will suffer.
