testing fuel pump and pressure
Old Feb 3, 2016 | 06:50 PM
TTVYSS's Avatar
Default testing fuel pump and pressure
Hi - I have just recently completed a fuel system for LS3 an installation into an early model Holden Commodore. I am allowing for higher HP capability in the future and hence have run -8 line from the Aeromotive 13301 regulator mounted near the tank (with a return line) which has Walbro pump. I have also included a fuel pressure gauge.
Question is - can I safely test the fuel pressure without the engine running (ie I plan to simply manually hook up power to the pump)?
thanks
Old Feb 4, 2016 | 06:52 AM
svslow's Avatar
Yeah you can do that. It will just pressurize the system and you can check for leaks.
Old Feb 4, 2016 | 05:43 PM
TTVYSS's Avatar
thank you!
