Corvette FPR on return system
Old Mar 22, 2016 | 11:44 AM
Prostcelica's Avatar
Default Corvette FPR on return system
Hi All
I think I k ow the answer to this question but thought I'd confirm as I'm not 100%. Can this regulator/filter be used I. A return style system? If not can you guys recommend a alternative for around the same kind of money. Thanks
Old Mar 22, 2016 | 01:46 PM
sweet99ss's Avatar
What are you wanting to use it on? I'm going to replace my fuel filter with one on my 98 ss and run a return line to the tank.
Old Mar 22, 2016 | 02:40 PM
I'm swapping a 4.8 from a 2001 1500 into a 67 Chevelle. Using a fuel tank from cross Canada with a in tank pump. I'm just not sure if the regulator I posted is for a returnless system only.
Old Mar 23, 2016 | 08:08 PM
This is the way I intend to hook it up.
Old Mar 26, 2016 | 07:13 PM
Old Geezer's Avatar
That's the way it's intended to be used.........
