Injector questions
Old Mar 26, 2016 | 08:29 PM
Pinchecharlie's Avatar
Default Injector questions
Iam swapping a 5.3 lm7 into 49 shoebox. I have a ls6 manifold and fuel rails but no injectors. While I search it seems that all the stock injectors are for a 5.7 ( manifolds origins?!) Iam just doing a stock lower end and heads it will get the manifold for hood clearance and headers because of clearance issues. Do I need the stock 28lb Bosch injectors or the typical swap injectors or are there more options for this manifold and 5.3? What vendors should I be using for stock replacement parts? Thanks Charlie
Old Mar 26, 2016 | 09:42 PM
Rise of the Phoenix's Avatar
You should be able to run any of the stock LS injectors without any issues, as long as you have the correct o-rings. No need for bigger aftermarket injectors at your power level.
