Fuel Pump Issue again...
Old Apr 26, 2016 | 12:00 PM
smws6ta's Avatar
Default Fuel Pump Issue again...
Ever since my Racetronix fuel pump died and was replaced I've been plagued by an electrical gremlin that doesn't go away. It's so random that I haven't been able to track it down or get close to the area to zero in on it.
It will randomly cut out, sometimes if I hit a bump, or if the road is wavy like when you go across a bridge BUT yet if I move the wires it won't cut out but when it does cut out I wiggle the wires (see pic below) and it comes back on or if it happens while in movement I can rock the car a little and 50/50 it comes back and I don't have to stop. It's worse when I start getting under 1/2 tank.
I thought it was a loose connection or ground and have pulled the pump several times and see nothing.
The arrow is where I jiggle the wire harness going into the tank. I've chased all of the wires and can't find any shorts, cuts or broken wires. I've even used a multi-meter to check for connectivity and if volts are proper. Both answers = yes.
Old Apr 26, 2016 | 12:05 PM
KCS's Avatar
KCS
Moderator
Let's try moving this from Gen III Internals to a more appropriate section and see if that doesn't help you get some answers.
Old Apr 26, 2016 | 01:03 PM
smws6ta's Avatar
Thanks not sure why I placed it there...
Old Apr 27, 2016 | 09:30 AM
IDriveChevy's Avatar
I had the same problem, and it turned out to be the relay(s). The one under the drivers dead pedal and my racetronix hotwire relay both had loose pins so I had to tighten them up to make the issue stop.
Old May 2, 2016 | 03:05 PM
smws6ta's Avatar
All this time I thought it was in the fuel tank and it turn out it's was around the relay. I cleaned up the ground point and re-routed the harness so that it was closer to the body and zip tied it into place. Seems to be working for now.
Thanks
Old May 3, 2016 | 09:54 AM
Thanks
What I will do after fixing mine is grabbing it and shaking to simulate vibration/bumps while driving to make sure it doesn't cut out on me again.
Old May 3, 2016 | 01:54 PM
smws6ta's Avatar
Ditto, that's how I ended up finding it.
Electrical issues I loath....
Old May 3, 2016 | 05:12 PM
Orange Juice's Avatar
Racetronix sent me a connector kit to replace the original one. They said they had a tendency to fail.
Old May 5, 2016 | 04:28 PM
smws6ta's Avatar
This **** is pissing me off.....it came back again. Getting tired of being stranded on the side of the road. It's getting dangerous.
I emailed Racetronix, awaiting reply.
Old May 6, 2016 | 09:44 AM
If that's the case I'll have to email them and see if they'll replace it for me.
Old May 11, 2016 | 04:07 PM
smws6ta's Avatar
It's been a week now and no response from Racetronix on email.
Old May 11, 2016 | 04:20 PM
Racetronix's Avatar
LS1TECH Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Please use our web contact form to reduce the chance of SPAM rejection.
http://racetronix.com/contact/
Please provide your e-mail address for reference.
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
Old May 12, 2016 | 09:26 AM
smws6ta's Avatar
I've signed up for your support forum but have not been able to see or post anything.
Old Jun 28, 2016 | 01:32 PM
smws6ta's Avatar
I bought a new harness and for now it seems to have fixed the issue. Not sure still what was messing up but for now hopefully it's fixed.
Xfingers....
