Enough Fuel?
Old Apr 27, 2016 | 01:04 PM
5.7stroker's Avatar
Default Enough Fuel?
Link to mods is in my signature.
For running a nitrous outlet 200 wet shot using the Fast 92mm plate kit, I'll need to update by fuel pump and injectors.
Will 2010 Ford GT 500 injectors work with a Fast 92mm intake and factory fuel rails with the proper EV1 to EV14 adapter kit?
link to injectors: http://www.americanmuscle.com/mustan...injectors.html
Adapter kit: http://www.americanmuscle.com/mustan...apter-kit.html
Is this racetronix fuel pump with hotwire kit sufficient for my power level:
http://www.ws6project.com/user_stor/...x-fuel-system/
Anything else fuel related that I need?
Old Apr 27, 2016 | 09:48 PM
5.7stroker's Avatar
Guess I'll go with Lonnies dual pump kit.
RX-F99-GSS340-DP-PKG
If I need a FPR and aftermarket rails or lines down the road, I'll just add them.
Old Apr 29, 2016 | 08:55 PM
mike431987's Avatar
I know the Ford 80 lb injectors have the same part number as bosch 80 lb injectors for ls2. Not sure how it will apply to yours but I know some parts are interchangeable. I am curious if the lonnies dual kit can work without a fpr and aftermarket rails
