Fuel pump or PCM?
Car starts perfectly fine 50% of the time, starts instantly, no issues. If it starts it runs perfectly fine until I shut it off.
Other times it will crank and not start, checked fuel pressure at rail, nothing.
I replaced the fuel pump relay, fuse and filter, but was told there is another one under the passenger kick panel, but I can't find any pictures or info to back this up.
It's just really random, the other day I left work stopped to get something at home depot. Came out it would not start, just kept cranking. Had it towed home, tried it again, nothing. Came back out an hour later, starts 1st try instantly no cranking.
No security light, so no VATS issues. I'm wondering if it may be a bad PCM. Do fuel pumps randomly stop working for an hour?
Finally I looked and found there was a code P1632 which was a security measure that disabled the fuel pump for some reason. I cleared that code in my tune and now I'm building pressure just fine with the key on.
Check to see if you have any codes come up.
