Injectors????
Old May 12, 2016 | 05:25 PM
hamood91's Avatar
Default Injectors????
im doing fast LSXRT™ 102mm intake on 5.3 (2000 Gmc sierra 1500)
about the injectors can I used the stock injector or (8) PRECISION-FLOW™ LS2-TYPE 33 LB/HR INJECTORS (http://www.fuelairspark.com/fas/8-ls...-injectorhtml/)
which one should i use ????????
Old May 13, 2016 | 04:28 AM
hamood91's Avatar
anybody? I mean which injector will fit perfectly in fast intake
Old May 16, 2016 | 08:37 AM
JoeNova's Avatar
Restricted User
That's a lot of money for such small injectors...
Do you plan to have it tuned?
Old May 16, 2016 | 10:15 AM
hamood91's Avatar
Actually I don't wont to change the injectors because its to much for these small injectors .
Old May 16, 2016 | 10:39 AM
JoeNova's Avatar
Restricted User
Do you plan on swapping cams?
If you don't plan on cam/injectors/tune, that expensive intake you bought it just going to be an expensive piece of eye-candy. It won't give you any real power gains because you won't be moving enough air to need an upgrade from the factory one.
You can get OEM 42 lb injectors for like $100. Or stock flex fuel truck injectors for about the same price.
Old May 16, 2016 | 10:44 AM
hamood91's Avatar
ya i plan to swapping cam and tune before i put this intake
can you give the part number for the flex fuel injectors
