FPR in Trunk?
Old May 22, 2016 | 06:59 AM
z28zane's Avatar
Default FPR in Trunk?
Turbo 5.3, Dual Bosch 044, 8AN Feed and Return. Fuel Cell mounted in trunk... Now my question..... If I go Pump>Feed>Rails>FPR>Return ... Can I Mount my regulator in the trunk by the fuel cell????
Old May 22, 2016 | 10:58 PM
Majestic9C1's Avatar
should mount it as close to the fuel rail as possible..
at least thats my understanding
Old May 23, 2016 | 09:35 AM
JoeNova's Avatar
Restricted User
You could dead-head it and put it on the Feed line close to the pump so that you have a very short return line.
Old May 23, 2016 | 01:06 PM
z28zane's Avatar
Meaning mount the regulator right into the return port of the fuel cell and then my feed into it when I come back from rails?
Old May 23, 2016 | 01:41 PM
JoeNova's Avatar
Restricted User
No, you feed into it right after the pump, and then the return line doesn't have very far to go to return to the tank.
Its placed on the feed line, not the return.
This is how 99% of returnless setups are done from the factory. A lot of those times, the regulator doesn't even make it out of the tank.
