LQ4 returnless fuel system question
Old Jun 15, 2016 | 08:12 AM
bigdaddy350's Avatar
Default LQ4 returnless fuel system question
I'm in the process of doing a LQ4 swap in to my 72 Chevelle. I know the LQ$ i am using, 2000 model yesr, uses a return line at the rail. My question is, can i use a corvette filter/regulator and just "cap" off the factory return feed at the rail? Maybe use a pressure gauge or some thing? Thanks!
Old Jun 15, 2016 | 05:59 PM
JoeNova's Avatar
Restricted User
You can cap it off with the right fitting. You just need to make sure its a fitting designed as a block-off, or one designed to screw a gauge into. Putting something like a vacuum cap and a hose clamp on it is asking for a fire.
Old Jun 18, 2016 | 11:27 AM
rpturbo's Avatar
My question is, why?
Old Jun 18, 2016 | 08:46 PM
Mostly because i don't want to run 2 new lines from my tank.
