BCM and Fuel Issues
Old Jun 21, 2016 | 02:39 PM
smws6ta's Avatar
Default BCM and Fuel Issues
I've been having random cutoff of fuel issues for a couple of months. I've gone through everything, connectors, wires, pump everything. I though it might have been a bad relay I have the hotwire kit form Racetronix).
Well last weekend I had BCM issues and found 2 of the spots were cracked so I re-soldered the 5 spots and everything is working normal.
When I was checking into what signs of a bad BCM one of the things was it cuts off the fuel injectors. Is this true?
And if so could it cut them off while the car is in motion and say hits a bump?
