85lb injectors on stock pump ?
This will be on a stroker motor running 93 oct
Motor is a 416, will get FI in the future. I plan on just doing a upgraded aero 340 pump.
Id rather not go return .
Is it possible or will it be a nightmare to get it to idle and run right with the 85s ?
You're going to need more than a 340 pump once you want to go forced induction, and you're going to have to go return as well (even if dead-head).
I was under the impression the stock hat and regulator could handle a aeromotive 340 pump. I see a lot of people just drop the pump in ?
I would prefer less cube but it's what it is so I'm going to work with it.
My goal is to try to keep it a street truck, a lot of the boosted Tbss guys have cooling issues.
