New fuel pump module
the one I picked up is a Delphi FG0154
I really dont wanna hack up a brand new assembly if I dont have to..
got the pump, hotwire kit, bunch of A/N fittings and hose and billet rails (already installed)
then I need time to do it since I am gonna drop the tank
I can't remember, but I believe 4th gens have an inline inlet. The Aeromotive pumps we bought have the center inlet. You'll need to cut a new hole for the center inlet. Don't practice on the new casket... use the old one for a practice mock-up. After getting the old casket cut properly, measure your cuts and transfer the measurements to the new casket for cleaner, more precise cuts.
Look at the Aeromotive install sheet (http://aeromotiveinc.com/wp-content/...1141_11142.pdf) Need to be sure the vapor purge port is unobstructed to prevent poor purging.
flex feed tube was made by Satan himself.. took forever to get it on....
also de-pinning the level sender wires was tedious....
but its all in and looks like I didnt touch it after I put it all back together..
but its pretty straight forward.. (dont use the rubber fuel tube that came with the pump) get the plastic flex tube that Racetronix sells. I did wait till I got my package from Racetronix today which consisted of a new fuel pump to sender harness (made it much easier since I only had to transfer over the sending unit wires), fuel tubes and 280 to 150 adapter harness.
I also took the regulator off and just put the little tan screen back in since I am going to a return style system.
part number for the in tank harness is ITWH-024
I also got the conversion harness as well part number is FPAH-004
I'm nickel and diming myself. A few weeks ago a couple bucks wasn't an issue, but now my wife is prying and asking to see the total expenditures over the last 2 months for my project. I need to keep enough cash to build me a doghouse by the pond...
https://ls1tech.com/forums/parts-cla...y-hotwire.html
Its just more flexible and doesnt kink... I wanted to make it look more factory since the OEM hose is the same style..
