Fuel pressure questions
I plan on installing a racetronix with a hot wire kit.. being I have a mail order tune I should be able to slap the new assembly in and keep my tune the same correct? I figured even if pressure is over 58 the fuel pressure regulator should keep it within spec right?
I appreciate any input! curious to see if this is normal or if I'm missing something.. also interested to hear what I should expect after changing the fuel pump.
Thanks
I was searching and getting mixed results.. is it from tieing into the fuel rail that we see the drops like that?
