internal or external pump?
Old Nov 1, 2016 | 02:42 PM
jimmyp3353's Avatar
Default internal or external pump?
I have a 98 Z28 that a carb'd LM7 is going into. I'm using the stock tank. Would it be better to run an external pump or an in tank pump? If in tank, do I use the regulator in the tank, or ditch it somehow. If external, how would I plumb it using the stock tank. Isn't much movement in the carb section.
Old Nov 4, 2016 | 09:25 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
An internal pump is almost always better, except when you can't get one big enough to supply your needs. I doubt this is the case at this point. If you use the in-tank regulator, you would still have to run an additional external bypass regulator to get the pressure down to carb friendly levels. Now that I think about it, didn't '98 still use a return style with a rail-mounted regulator? If that is the case, you just run a low pressure regulator to feed back into the factory return line, and the only plumbing you have to change is under the hood. As a bonus, the factory pump will flow quite a bit more at 8 or 10 psi than it does at 58.
Old Nov 7, 2016 | 09:21 AM
jimmyp3353's Avatar
Thanks. Much appreciated
