Fuel pump Questions ASAP?
Old Jun 23, 2004 | 12:06 AM
GreenHornet37's Avatar
Default Fuel pump Questions ASAP?
My buddy who is a GM certified mechanic is installing my fuel pump in my car. He says that the pump wont fit. It is a Walbro 255 #Gss307. Is their any difference in the years for the pumps? I looked It up on walbro'swebsite and the say it is the same pump for 1985 to 2002. I dont know what to do. HELP!!!!
Thanks,
Zach
Old Jun 23, 2004 | 07:10 AM
onfire's Avatar
Coal Mining Director
I think you need the 340.....plus it's not a direct bolt in unless your car is a 1998 and are using the Racetronic pnp. The 340 will fit with some mods....lots of folks using them on 1998 and up.
Old Jun 23, 2004 | 10:39 AM
Nasty N8's Avatar
Yes you need a 340M the 307 does not have enough pressure to run at 60psi. And yes none are a direct bolt in it requires some fab work.
Nate
Old Jun 23, 2004 | 01:27 PM
MIGHTYMOUSE's Avatar
your certified mechanic friend should be able to figure it out... after you go get the right pump.
do a search here for fuel pump install pics.
