Which fuel system setup?
Anyway, here is how I currently have it setup. It's -8 all the way up, crosses over, and returns through the stock feed line.
Here is how I am thinking about switching it up. This will be a -8 from pumps, through filter, to a -8 y-block, then run -8 to each rail from the rear, and -8 out the front to the regulator and back into the stock feed as the return. Would there be anything wrong with the -8's after the Y? It seems most will use a smaller line to rails.
With the built shortblock I would like to shoot for 900+rwhp with the billet S480 but dyno numbers are just that, numbers. I went 5.98 @ 119 last summer with the SBE and the fuel setup in the first picture. I ran it like that for 4 years and never hurt the SBE either. Granted I wasn't making as much power as I want to make this year though.
Any opinions on what would be best? I realize option #2 is going to cost quite a bit more but if it would be substantially safer for my new setup I have no problem spending the money.
Thanks!
In for info and results on this!
That said I've upgraded to a 4303 this year and it recommends -10 feed with -8 return. But I also upgraded to a magnafuel 2000hp regulator
