Question about throttle body sizing..
I would think the intake runners are the limitation but what else should I be thinking about for proper sizing.. ??
Haven't found anything that explains it ,, at least that sounds correct..
Now you can cam the throttle to slow it down, but in the end, if your motor can use a 75mm throttle body, and you bolt on a 100mm unit, once you get to 3/4 throttle nothing else will happen since the motor physically cannot suck anymore air in
In a turbo application i try to match intercooler piping and throttle body together
All engine dependent of course
