fuel pump runs non stop
So today I go to start it and it cranks and sound like it almost starts but it doesn't. Tried it a few time still not start but i do notice my fuel pump whines and runs non stop with keys on accessories and runs non stop till i remove the key. I checked the fuses everything looks good, but i have not checked the relays. Does this sound like a relay problem and it not shutting off fuel pump or fuel pump just crapped out? The battery charge is low but it should be enough to start my car but maybe screwing the pump up?
What is ya'lls take on this, i'll prob end up changing relays and then fuel filter hopefully this will fix before moving on to fuel pump.
Also I'll add that i didn't see and water or wet area around the ecm
