Rocket Scientist required
After much reading I get I was hasty and shouldn't have bought them, didn't do my home work.
are you referring to my vehicle details? It's a 2007 Chev Lumina SS, come std with a 6.0l L98 ls engine. It basically the South African version of the Holden Ve/Pontiac G8. Comes with a gen 3 e38 pcm. I've just built a Warhawk 427 with trickflow 225cc heads and a trickflow can 220/224. I calculated the cylinder volume to 89.52cc usuing online calculators.
As far as Ive found out the stock injectors are 42lb @43.5 psi running on 58psi return less fuel system.
Even if these injectors are **** and I need to get others could you please explain how I interpolate the various data in the pcm tables?
