LS2 injectors with EV1
Old Sep 9, 2017 | 09:22 PM
EvilWS602's Avatar
Default LS2 injectors with EV1
I'm am searching for and LS2 length 42# injectors with EV1 connector. I know I can get the adapters or change the pigtails but I want to try this option first for the ease before going another route.
Old Sep 17, 2023 | 12:07 PM
hpbob130's Avatar
Cool Larger injectors for TBSS intake & aftermarket rails needed
Hi Guys, I have a TBSS instake on my 6.0 LS with my twin borgwarner s366 turbos. Currently Im running Snake Eater 100 lbs or 1000 cc injectors. However my chassis dyno guy says I need larger injectors to turn up boost more as Im running e85. I tried the snake eater 150 lbs 1500s, but they are shorter injectors than the truck multec II style snake eater 100 lbers with same outer dimensions as stock truck injectors. So the new snake eater 150 lbs injectors are shorter. I tried 3 different injector extenders called top hats to make the shorter peco style fit under my aftermarket fuel rails in my TBSS intake. However I cannot get these new injectors with top hats to seal under the aftermarket fuel rails.
The 100 lbs stock style snake eaters seal perfectly because they are all 1 length.
Anybody using high impedance 150 lbs or larger injectors in a TBSS intake with after market rails? If so what injector & where did you buy them? Im running a terminator X so they have to be high impedance injectors. I can always get adapter pigtails for the electric hookups. I just need some larger injectors that will seal under my fuel rails! The holes in the fuel rails are drilled straight down & not at an angle like the intake injector holes. So when I use top hats the angled injectors from the intake dont seal under the rails. But the solid all 1 piece longer stock style snake eater 100s do. Snake eater keeps sending me different top hats to try. I have tried 3 different ones and they wont seal or work. I just need 150 lbs or larger injectors that will seal & work with my TBSS intake and after market rails. I dont want to pay 1300.00 for injectors. I paid 785 for these snake eater 150 lbs injectors that wont seal even though they are advertised to work on a TBSS intake. Thanks for any help!
Old Sep 23, 2023 | 11:16 AM
Old Buzzard's Avatar
