80lbs deka
Old Sep 25, 2017 | 09:43 PM
Marker1ls's Avatar
Default 80lbs deka
I'm running 80 lbs dekas,had one hang up,was told there to small when I called fic,I have a 443 ls7,carteck heads, holley high ram with 102 tb and 255 racetronics pump,my afr has been reading lean at wot,pretty much 14.44 crossing the stripe in the 1/8,should I get bigger? The guy told me I was to small?
Old Sep 25, 2017 | 09:52 PM
What is your fuel pressure at WOT? Your pump might not be quite up to the job if the pressure is dipping. Otherwise, yeah, you might be maxing the injectors out.
Old Sep 25, 2017 | 09:56 PM
JoeNova's Avatar
Restricted User
Maxing out deka 80s N/A? Doubtful.
You have a Walbro 255 pump. That thing will only flow about 65% as much as the deka 80s will. You're probably out of fuel pump.
Old Sep 25, 2017 | 10:21 PM
Yeah, I didn't know how to co-relate what he has to how much fuel he can suck down. I knew those were humongous injectors, but didn't know how much fuel his setup used. The 255 pump should have been a clue. Must be getting too late at night... lol
