Fuel injector replacement
Old Oct 22, 2017 | 05:01 PM
00ssSixspeed's Avatar
Default Fuel injector replacement
I just got my bbk high flow fuel rails for my 00 ss today. I was thinking of replacing my injectors while I was changing my fuel rails. Any recommendations on the type I should get? I've seen different types and prices out there. It looks easy enough to install myself. Or should I let my tuner install them because I'm sure if I got higher output injectors he's need to tune it to the new injectors. Any input would be appreciated.
Old Oct 22, 2017 | 07:36 PM
Crf450r420's Avatar
You need to figure out your total power once your mods are all done and get ones large enough that you make the change once. Injectors alone will make no power. You will need to change the injectors size in the computer to bring the AFR to normal or it will run rich. There are a couple types of injectors and many different styles. Holley injectors are very reasonably priced, but the disc injectors provide a better idle. I'd say find Lance of Pantera EFI on here and get a price from him. He has a well priced 47lb injector that is stock LS1 height and they are flow matched already. I'm sure he the price will be close to that of others that don't get flowed. We have used hundreds of sets of them and they work very well.
Old Oct 23, 2017 | 02:32 PM
Thanks crf. I appreciate your input.
Old Oct 23, 2017 | 07:41 PM
Crf450r420's Avatar
no problem
