1st Gen Firebird Camaro fuel system
I have installed a few on the pass rear inner frame rail, and a few up high on the underside of the trunk. It's easiest to find a good spot for it, then measure for your flexible lines to the tank & to the fuel hard line. If you dont already have a tank, the rick's resto mod tank with the gen 5 pump is internally regulated and is the best setup out there for the money. And you'd only have to run a single line from the hardline to the tank.
Thanks, I bought a similar set up from Tanks Inc. Their website was more user friendly. I was eyeing up both spots you mentioned. Thanks again
