E85 help
Old Nov 12, 2017 | 12:04 PM
SlicksNchicks's Avatar
Question E85 help
Sorry to beat a dead horse but I found out some local stations do have e85 and since I haven't completed the build, I'm opting for e85 instead of 93. 5.3 with a maggie running 14-15psi which I'm guessing/hoping should make 500-600whp range on e85. Will an Aeromotive 340 and 60lb injectors be enough for what I want on e85? Or should I find some 80lb'ers? Bigger pump? Thanks for any input.
Old Nov 12, 2017 | 12:51 PM
dw456post's Avatar
I have a 6.2 using two DW340's and ID850's which are 94# at 58psi. At wot and 11# boost, I am at 75% injector duty cycle. I never tried running just one pump, but I think one would be too small, or get a 450 ? Maybe some of the turbo guys will chime in.
Old Nov 12, 2017 | 01:19 PM
pantera_efi's Avatar
Default E-85 = 50 % derating
Hi, NO the 60's are not large enough.
The 85-90 .lbs "tech" is correct.
I provide this size often ?
Lance
Old Nov 12, 2017 | 05:40 PM
Awesome thanks guys. A1000 pump too much? My buddy has a new aeromotive cell with the a1000 he said he'd let go for 500. Panera I'll be in touch for some injectors.
