Suggestions for paramaters on custom fuel fail-safe on boosted engine?
I've been trying to figure out a way to do it based on fuel pressure in the past, but a gauge that can send a signal under predetermined boost & AFR conditions is a life-saver given enough time. My best guess is any positive manifold pressure with an AFR over around 12.2. I guess the only thing that pops into mind is that I see lean spikes between power shifts that I have so far been unable to tune away. If the system is fast enough, then it won't matter.
