flex fuel injector
Old Dec 14, 2017 | 01:26 AM
scottdanny22's Avatar
Default flex fuel injector
I have a 2002 suburban 5.3l flex fuel i just replacewd the intake and the fuel injector orings now one of the injector leaks upon start up, bAre the orings and injectors different on a flex fuel motor do the orings interchage from a standard motor injecter and a flex fuel motor? thanks in advance
Old Dec 15, 2017 | 12:33 PM
Lsxford's Avatar
The flex injectors flow more fuel. The orings are the same iirc. If you only have 1 leaking id bet it got cut during assembly.
Old Dec 8, 2020 | 09:00 AM
Lonnie Lee's Avatar
Default He’s right
I had a couple get cut always keep extras the trick is lube the o ring put all the injectors in the rail first while it’s off then put them in the intake
Old Dec 10, 2020 | 03:11 PM
AUS Injection's Avatar
As stated before, I bet that leaky injector is due to a bad O-ring. I would recommend using Vaseline when installing so they don't get pinched and tear. Good Luck
Old Dec 10, 2020 | 03:39 PM
Lsxford's Avatar
This thread is 3 years old, i hope he got it fixed by now.
Old Dec 10, 2020 | 03:41 PM
Lets hope so, lol
