filters?
Almost if not all in tank pumps have a sock type filter on the end of the pump or pump pickup.
Inline filters rarely have a micron count that would capture anything that got by the in tank filter.
I suspect the in tank filter would plug up long before the inline filter?
What am I missing?
If the inline filter is mandatory - what minimum micron rating should it be ?
You can't put a 10 micron filter before the pump because it creates too much restriction, and the pump can't draw through it. Electric pumps don't suck.
Also, every once in a while, the pump will have a catastrophic failure, and dump shrapnel into the fuel line, so you need a filter to keep that stuff out of the rest of the fuel system.
