Fuel
Old Mar 2, 2018 | 04:19 PM
Tx432noobcomer's Avatar
Default Fuel
So I just bought a 2011 Camaro with the 6.2 l. And in the owners manual it says that I need to run 93 octane But around where I live I cannot find anything higher than 90 so what do I do to remedy this problem. Thank you for all the feedback and help
Old Mar 2, 2018 | 05:48 PM
abbas461's Avatar
this may help
Here it is word for word from the manual itself section 8-44 Recommended Fuel:
if the vehilce has the 6.2L V8 engine (VIN Code W) or the 6.2L V8 engine (VIN Code J), use premium unleaded gasoline with a posted octane rating of 91 or higher. For best performance, use premium unleaded gasoline with a posted octane rating of 93. You can also use us regular unleaded gasoline rated at 87 octane or higher, but the vehicle's acceleration could be slightly reduced, and a slight audible knocking noise, commonly referred to as spark knock, might be heard. If the octane rating is less than 87 a heavy knocking noise might be heard when driving. If this occurs, use a gasoline rated at 87 octane or higher as soon as possible. Otherwise, you could damage the engine. If heavy knocking is heard when using a gasoline rated at 87 octane or higher, the engine needs service.
Old Mar 2, 2018 | 06:55 PM
Thank you but isn't spark knock damaging to the engine?
Old Mar 2, 2018 | 07:24 PM
B52bombardier1's Avatar
Yes, it is damaging. I'd be looking for an octane booster fuel tank additive at my local auto parts store if you can't find a higher octane fuel.
Rick
Old Mar 2, 2018 | 07:26 PM
Which would you recommend because I have yet to find one that has good reviews
Old Mar 2, 2018 | 09:44 PM
It is hard to go wrong with "VP" products though a little spendy.
http://www.jegs.com/i/VP-Racing-Fuel..._wcB#reviewTab
Rick
