LS3 FAST 102mm TB
Old Apr 29, 2018 | 04:10 AM
Pault68's Avatar
Default LS3 FAST 102mm TB
I'm building an LS3 to install in a Factory Five 33 and recently replaced the standard throttle body and manifold with an LSXR manifold and FAST 102mm bigmouth throttle body with TPS and IAC. I'm also going to cable throttle rather than DBW. Can anyone tell me if there's a patch cable available to go from the TPS and IAC to the standard harness plug (six pin plug). If not, has anyone else done this type of conversion.
Old Apr 29, 2018 | 10:02 AM
The Gen IV PCM can't be converted to cable throttle. Which PCM are you using?
Old Apr 29, 2018 | 05:59 PM
Pault68's Avatar
Thanks G Atsma, If have an E38 PCM (12628989, serv #12625455).
