Plastic Tank and Sending unit
Old May 22, 2018 | 06:20 PM
codyashby21's Avatar
Default Plastic Tank and Sending unit
I need some help please, I have a 98 Camaro that sat so long the fuel tank rusted. I’m going to switch to a plastic one but I also need a sending unit but have only found the pump and unit together. Where can I buy the sending unit and the tank?
Old May 23, 2018 | 09:45 AM
dlandsvZ28's Avatar
Rather than going thru the hassle of switching/converting everything over to the 99-2002, have you considered buying a new 98 metal tank.
https://www.partsgeek.com/gbproducts...ad=47433966132
Might want to do a search on the changes needed to convert to 99 and up. If it were me I would opt for an new tank or try to find a good condition 98 tank. Lots of info on this forum.
https://ls1tech.com/forums/fueling-i...-write-up.html
Might check with Lonnie or the WS6 store. I dont think the sending unit is replaceable - think you have to buy the entire module. According to one vendor, if your existing sending unit is good, keep it as the new sending units are chancey with a new module.
http://www.ws6project.com/user_stor/.../fuel-systems/
http://www.lonniesperformance.com/fuelsystems.htm
