Racetronix pump hotwire problem
Old Jun 5, 2018 | 08:50 PM
Cole Train's Avatar
Default Racetronix pump hotwire problem
I have a Racetronix pump kit(purple pump) and a hotwire kit. I had an issue the other day where my pump wouldn't prime. On the top of my pump assembly i have a flat 3 pin plug and a 4 pin square plug. When i bypass the hotwire kit the pump always primes. When i add in the hotwire kit it usually primes but if i wiggle the square connectors associated with the hotwire kit it intermittently doesn't work. I'm not sure if it's a pin not having a good connection or what but if i can i would like to get new connectors and pins and i'll rewire them. I just don't know what connectors it is i need. The OEM harness doesn't appear to be the issue because when i don't use the hotwire plugs it primes every time.
