injector help please
Old Jul 10, 2018 | 02:46 PM
tom70's Avatar
Default injector help please
building a lq9 with 243 heads, titan 2 cam(Duration at .050": 221/226, 112 Lobe Center Angle with a 110 Intake Centerline, Lift with 1.7 Rocker Arm Ratio: .595"/.586"), ls6 intake. what sized injectors will I need for this build? worried stock injectors won't be big enough.
thanks
Old Jul 10, 2018 | 02:58 PM
ss.slp.ls1's Avatar
thanks
I would pick up some 42# injectors.
Old Jul 13, 2018 | 11:27 PM
tom70's Avatar
Looked at these injectors gm 12609749. Will these work or do I need aftermarket ones?
thanks
Old Jul 16, 2018 | 12:09 AM
ss.slp.ls1's Avatar
thanks
Those are EV6 style injectors that are shorter (LS3 style). You'll probably want some aftermarket ones like these from Texas Speed:
https://www.texas-speed.com/p-6704-f...-set-of-8.aspx
Old Jul 17, 2018 | 11:30 AM
tom70's Avatar
thank you
Old Jul 17, 2018 | 01:03 PM
eaglegoat's Avatar
Don't do that. Run the GM injector. There are top adapters for the height differences and there are connector adapters for the electronics. MissedMo infectors are garbage. The same injector flowing more fuel will have different characteristics.
