Help with fuel system
96 Impala SS
LSX b15 376
LSA supercharger, ported TB
2.45 pulley
1 7/8ths headers
E67 ECU / harness by BP
Auto trans
Shooting for 650WHP on E85 using a flex fuel sensor/tune. I may wish to spray a 100 shot down the road. I currently have an Aeromotive Phantom 450 in tank pump (450 LPH Aeromotive pump in their custom bucket). I know it won't get close to supporting 650whp on E85 so I'm looking for some other options. It's daily driver so no big/loud external pumps like A1000's/ProTuner 750's. Here are some options I have thought up
Simply install a BAP on the 450 Phantom. Not sure how much more that would get me. I'm sure it wouldn't support the nitrous but if this would support 650whp on E85 I would do it as it's a cheap option to get things working for now on just boost.
Swap the 450lph pump out for two Aeromotive 340LPH pumps. I'm pretty sure Aeromotive's "twin phantom" system uses the same bucket and all as my single 450LPH, so I could just buy the pumps, another harness and swap it in. Not sure if those could hold up to E85 long term?
I'm new to LS swaps and I'm not sure if maybe I should be looking into incorporating factory CTS-V fuel system parts with an upgraded fuel system kit made for a CTSV retrofitted to fit my tank (like FORE innovations , Squash or even DSX aux pump), or if I should just do what I have done on most of my cars and run a typical feed/return system with an aftermarket boost referenced regulator.
I didn't plumb the car yet so still determining feed/return size. Most likely going to try to run hard line, I was thinking 1/2" feed 3/8" return.
Any help is appreciated!
Still trying to figure out what to use for a fuel pressure regulator and how to activate the 2nd pump. Not sure if the factory FPR from the CTSV/ZL1 could handle the added output of these pumps and added requirements of E85 or not. Also wondering if I should set the second pump on a hobbs switch or if there is some way to use MAP signal from the E67 ECU to activate it instead.
