Fuel level Gauge issue
Old Aug 19, 2018 | 08:14 PM
5.7stroker's Avatar
Default Fuel level Gauge issue
When the stock tank is a full fuel capacity, where should the needle read on an untouched gauge cluster? At "F"? A few mm past it? I changed my fuel level sensor when I was doing my pump replacement because I had damaged it. Car was 3/4 full prior to making the changes. After the install, it still showed 3/4 full so I figured I was good. Filled the car up with gas, and the needle went past full. Thought nothing of it. Had the car out today logging trans temps and 20 minutes into city driving opened the cutouts on the highway, stabbed it, and my fuel gauge dropped to empty throwing the fuel level sensor high circuit code. Reset the code, and it when back to where it was prior to taking the car out, reading past fuel. I've put only 30 miles on the car since last fill. I'm guessing the new fuel level sensor has gone bad. Time to get back into that tank....again.
Old Aug 20, 2018 | 12:17 AM
sjsingle1's Avatar
what brand sensor did you use for a replacement ?
Old Aug 20, 2018 | 08:18 AM
5.7stroker's Avatar
I paid $13 for it from ebay user alanisdeals
Saw that he had sold 298 of them and rolled the dice.
Brand is ADP, part number SU-SK6
Should have just bought a Dorman 911-005...... live and learn.
Old Aug 20, 2018 | 05:32 PM
sjsingle1's Avatar
i suspect the quality of the sensor too
