In Need Of More Help!!
Old Jul 9, 2004 | 11:42 PM
Pavlock Performance's Avatar
Default In Need Of More Help!!
i have a 92 chevy with the 350 tbi setup. i just put a bone stock motor in there with a vortec roller cam and thats all! everything else is stock. i had a heads and cam 355 and it sucked too much gas. now when the truck idle's, the motor's rpms go up and down and sometimes dies. i dont now if the idle/air sensors bad. i replaced it and theres no change. i put the timing to zero, then plug the computer switch back up and the computer takes it to about 2o something degrees total advance like it suppose to i hear. so any help will help. when i put it in gear, the idle is perfect. thanks
