gas tank question
My question is could I put in the 4th gen gas tank now, run all new ptfe fuel lines and a regulator up front. Then run a line from the regulator to the tbi and regulate the fuel pressure to the tbi specs?
Then I would be able to get rid of the stock evap stuff and get a head start on the ls swap.
As long as you can get a regulator able to bypass enough fuel to get it down to ~13 PSI or so, then yeah.
