Injector Size question need validation
Here is my build:
SLP Stainless long tube headers arp bolts
high flow cats
Flowmaster catback
LG G5X3 cam kit
BBK SSI Intake with BBK 80mm TB
4.10 gear with moser axles
K&N cold air intake
Weld in subframe connectors
mcleod racing Twin Disc with Aluminum Flywheel
Polyurethane motor mounts
Spohn rear suspension
SLP options: drilled and slotted rotors,
SLP front grill 17" chrome ZR1 wheels,
SLP springs,
Bilstein shocks,
Hurst shifter,
MSD plug wire set
T-Stat 160
EGR delete
Rollmaster Single Roller Non Adjustable timing set
I am looking at either:BOSCH GREEN GIANT 42LB
https://lightningforceperformance.co...PWtf0COyzmfL-o
Lucas 42.5 pound/hour Fuel Injectors
http://intense-racing.com/PROD/FIS-42x.
What do you guys recommend, I hear the Lucas ones are not as reliable, Also do i need to change the fuel pump.
Last question anyone in NYC area who can recommend a good tuner?
I was around 86% injector duty cycle with 36 lb injectors and 530 crank horsepower and a 255 lph walbro fuel pump. As far as fuel pumps go, if staying naturally aspirated, even a 255 lph pump would be more than enough for you and won't ever give any hint of overpowering a stock fuel pressure regulator (or the c5 filter/regulator).
SLP springs,
Bilstein shocks,
Hurst shifter,
MSD plug wire set
T-Stat 160
EGR delete
After all that, you left out what engine it is.......
Either way, if its a LS2 or LS3 I would imagine the stock pump will be fine, worst case, a BAP would definitely be sufficient. I imagine its pretty rare to require a pump upgrade for someone running no boost or spray.
