Ev1,ev6
Old Mar 11, 2019 | 11:15 AM
Jthompson96's Avatar
Default Ev1,ev6
Does ev1 flow any more or less than ev6? Ive seen a couple guys talk that theres a flow difference between the two.
Old Mar 11, 2019 | 03:46 PM
NCDEERE's Avatar
I believe that depends upon the injector. They will flow the amount they are designed to flow at a designated pressure. For example a 28 lb EV1 and a 28lb EV6 will flow the same at the same pressure.
Old Mar 13, 2019 | 01:00 PM
AUS Injection's Avatar
If they are rated at the same flow rate, the flow will be the same for both. Just different atomization and spray pattern.
