2002 Fuel pressure problems
Old Mar 20, 2019 | 06:11 PM
5o2slow's Avatar
Default 2002 Fuel pressure problems
I have a 2002 Camaro change the stock fuel pump to a Racetronix 255. Ever since my fuel pressure sit a 72 psi constant at idle or revving the motor. Removed and reinstalled the new pump even check the in tank regulator and still sits at 72 psi. And can’t tune the new motor because of this issues any ideals where to look?
Old Mar 20, 2019 | 06:16 PM
You might need a regulator. You checked it and it was 72PSI?? That should tell you it is bad.
