Injector selection
Old Apr 29, 2019 | 12:34 PM
Wskirvin's Avatar
Default Injector selection
I'm curious is anyone has a resource or can point me in the right direction of what injectors i should get. I have a lm7 that the short block is getting freshened up, then i have a set of 243's that i'll use with a TBSS intake and either a BTR stage 2 or sage 3 cam. I'm going to be running the new Holley Terminator X Max, but Not sure what Injectors I need to upgrade to or should I use the stock Trailblazer ones.
Old Apr 29, 2019 | 01:20 PM
If the injectors you have came off a Trailblazer SS, you should have enough injector for what you want to do. The SS had an LS2 in it putting out more than 400HP
Old Apr 29, 2019 | 01:22 PM
Wskirvin's Avatar
Thank you very much. I figured they would be enough, but wasnt 100% sure.
