Fuel injector replacement
Old May 6, 2019 | 09:18 AM
jimmyg's Avatar
Default Fuel injector replacement
So I had to do a knock sensor on my 02. Sierra hd 6.0. When I took intake off I noticed the ports were all gummed up except where injectors were spraying . 5 looked ok , but 3 didn't seem to be spraying as they should . I had
A used low mile long block put in 2-3 years ago
Trucks got 341k on it . It runs fine , no codes
But seems to be down on power . So I ordered new Delphi injectors off eBay . Same part number . Can I just swap them out? Or is there tuning involved?
Old May 6, 2019 | 04:59 PM
With the installation of same part number injectors, no re-tune will be required. Simple change out, no problem.
