boost a pump, QQQQ
Old May 31, 2019 | 02:19 AM
cmysix's Avatar
Default boost a pump, QQQQ
I'm running about 510 at the crank on an LS2, STOCK FUEL PUMP, 36LB INJECTORS using the racetronics hot wire set-up to the pump, better then stock ALT. Question is at what point do you need a BAP or is that for FI applications?
