Fuel system for boost help!
Old Jun 5, 2019 | 09:11 PM
cornfedss's Avatar
Default Fuel system for boost help!
Ok guys need some assistance with this please......
Motor is a 383, 9.35:1 compression pistons, afr 215 heads and I can post rest of my motor specs if needed. Motor should be about 550-600 and built for boost.
Will be installing an f1-a procharger race system with 10psi pulley.
Hoping to put 900 at the ground!
fuel system is what I need help with.....
just ordered the squash dual pump setup for the 99-02 fbody. Dual walbro 525 pumps, -8 feed, -6 return, oe plug in evap, and plug and play wiring harness
I have the lines under control.
Injectors... what size should I run with? Will id1300 be enough?
What rails and regulator should i go with as well?
I’m stumped and need help please
Old Jun 6, 2019 | 10:00 AM
AUS Injection's Avatar
Messaged you
Old Jun 6, 2019 | 11:24 AM
LilJayV10's Avatar
What fuel are you going to be running?
Old Jun 6, 2019 | 11:29 AM
cornfedss's Avatar
Originally pump gas but will be going to e85 so I want to build the system for e85.
What rails work work best with the lsxr manifold? What regulator should I run?
