Meth Vs Bigger Fuel System
I just recently got my car dyno'd. Made 377/363 with a sbe lq4 spec'd for boost. I currently am running a 255 pump and I plan to go to a p1sc or d1sc with a 6 rib setup (using poor man's belt wrap to hopefully eliminate pulley slip). I'm assuming I'll likely be somewhere in the 500-600whp range and obviously pushing the limits of my current fuel pump.
That being said, I'm weighing my options here. I really don't need much more fuel, if any at all, but like I said, it'll be close (but obviously I need something extra to be SURE). So I'm debating between going with meth injection system operated via a hobbs switch, a boost a pump, or running two pumps. Obviously two pumps would be waaaay safe lol. I've been leaning towards the meth setup because I have a friend selling a brand new snow performance kit for cheap if I want it.
Most of my friends say that running meth is a band-aid though and I understand the reasoning, but I see tons of people run hobbs switches on their double pump setups and I don't see the difference. The real risk for failure seems to be the hobbs, which if it fails in either scenario then things are going to break. Seems like all options are "band-aids" in a sense, unless you have a secondary pump with a manual switch that can run whenever you want it to or they're both constantly running.
Maybe I'm way off here, and tell me if I am. I don't mind. Just trying to learn some things and get some input from people with legitimate knowledge and experience on this.
Thanks!
I would not use meth system to rich afr. There is too many things what can go wrong and hard to tune.
As far as the meth option goes, I know it shouldn't be used as a substitute for fuel, but I'll be most of the way there if not there on my current pump. However, that depends on the numbers it makes, so I shouldn't make a decision based on assumptions/possibilities. I'm not concerned about the tuning aspect though. My tuner is probably one of the best in Ohio. I'd never go anywhere else.
elaborate
We are not going to fuel a high performance motor with water from a plastic tube, restricted at a single orifice intended for high pressure, from a pump which has a service interval (periodically replacement means eventually failure)
Because distribution problems at high flow rates of liquid content requires extensive plumbing. Furthermore optimum ratio of methanol is often found to be 70-80% mostly meth and because 51% methanol is flammable it isn't worth the risk to use this, the best possible liquid ratio for aux fueling on a street car.
Even if we could implement an elegant meth system with failsafes at high flow rates individual runner distribution etc... That would be awesome if you could actually use 75%+ meth, if the liquid wasn't flammable, too bad it is highly flammable so to be really safe driving around with such a system you're really spraying mostly water. It becomes a water distribution system. Which is great for pulling heat out of the engine, reducing the speed of combustion and reducing power output all simultaneously... Its a power remover button for turning down temperatures and its very easy to over-do. Very little water goes a long way so multi distribution isn't necessary.
